lampshuk
Hi, all. We bought a Moody 31 last November. Our first episode of boat ownership, so doing some routine maintenance jobs for the first time.
The pear-shaped hull anode needs replacing. I sprayed the external nut liberally with freeing oil but it refuses to budge - though the whole stud turns quite happily in the hole :-( - it was only after doing this and trying unsuccessfully to hold the interior nuts that I noticed a flat retaining "washer" on the outside that ought to be able to hold the stud steady. It's hard to get a proper spanner on it, though.
I suppose that, having spun the stud around, I will now have to draw it out and re-seal it.
But before that, I need to get the flippin' nut off the outside. Anyone got any strategies that work? I am slightly nervous of applying heat, given the proximity of the hull.
The studs seem to be made of mild steel. They have not rusted badly, but enough, it seems, to sieze on to the nut. Is there a better material to use for the stud? I have seen stainless steel ones on sale, but I thought their conductivity was poor. I suppose nyloc nuts won't work if the nuts provide some of the electrical connection.
Any tips for how best to proceed? I suppose this ought to be a simple, routine task, but as with all things nautical it seems that there are many "inconvenient details" that need to be worked through.
Thanks for any advice,
Lampsh.
Lampsh.
