Replacement tacho
andy_m
7 Jan 2003
Wiltshire
My starboard engine tacho is playing up (lazy operation - only kicks in above
3000 rpm). The problem has been traced back to the tacho itself.
This is an original part (circa 91/92) which I'm told is no longer available.
The diameter is 85mm whereas the only replacements available have a
96mm diameter.
Can anyone recommend a good source for older VP parts or a place which
can recondition the old unit ?
DepSol
6 Oct 2001
Guernsey
Try ASAP Supplies as they have Faria gauges that would fit. They are on the web
<hr width=100% size=1>Dom
2003 is going to be a good year for me
pistonbroke
3 Jun 2002
Down South
Beaulieu Boat jumble is a good source of new & used VP parts. You could use something like a faria, but I am assuming that you would want it too match the original.
tr7v8
30 Nov 2001
Kent
Send it to someone like Speedy Cables they'll repair it cheaper than a new one and it'll match its mate.
http://www.speedograph-richfield.co.uk/
I've used the former but heard good thing about the second.
<hr width=100% size=1>Jim
Draco 2500
Jerbro
9 Jan 2003
Wiltshire
If it's a VDO, VDO Mannessman in Birmingham will recondition it for £50 inc post and packing.
<hr width=100% size=1>Jerbro
Click here for <A target="_blank" HREF=http://www.jerbro.btinternet.co.uk> My ex-boat pics</A>
andy_m
7 Jan 2003
Wiltshire
Thanks for all your suggestions. I will explore the possibility of getting
the existing unit fixed so it matches the other one.
Andy
