AntarcticPilot
I'm thinking about replacing my cooker - it's done good service, but the oven doesn't have a thermostat and takes ages to reach a useful temperature, making it less than useful. I'd also like some form of built-in ignition; messing around with a lighter can be a bit of a pain! However, the ignition system should be self-contained; I don't want to have to make another connection to the boat's electrical system.
The existing Neptune 2000 is a pretty good fit, and ideally I'd like a drop-in replacement. There is also a worktop built into the galley furniture that can slide out over the cooker - I don't usually use it, but would prefer to retain the possibility. Therefore, the fiddles and pan holders must not extend too high above the burners, as appears to be the case with some makes (Banbury????). The existing clearance is perhaps 2-3 inches above the burners.
Suggestions?
Suggestions?
