Replace mast head aerial with Mast head Whip Antenna with Wind Vane question
kevsbox
10 Jun 2020
Portsmouth, UK
www.kevsbox.com
Hi all
We havea centaur whicxh has no wind vane and I am missing it, We have a mast head aerial as in photos and my queston is if I purchase a VTRONIX Mast head Whip Antenna C/with Wind Vane or similar is it simple replace, are the wire connectors all a standard type?
Thanks in adance for any thoughts
Kev
MoodySabre
24 Oct 2006
Bradwell and Leigh-on-Sea
The vtronix ones usually come with a cable and connector. Good opportunity to replace the old cable. You won’t know which connector is up there until you go and see it. Mousing a cable is quite straightforward.
samfieldhouse
18 Sep 2016
No, there are different connectors.
I replaced both my VHF and AIS aerials with Glomex Glomeasy models and corresponding RG8x cable - they use a specific connector.
An older aerial may have a different connector.
Refueler
13 Sep 2008
Far away from hooray henrys
WHY replace whip antenna ??
You can add a wind vane to an existing whip .... all it is is a V mount that grubscrews lock onto the whip - then a short tube with the vane on top of the locked by the lip of the V mount.
I've converted plenty of whips for this ...
mmmmm yes that's the bottom part of a small plastic Coca Cola bottle as my Anchor Light 'glass' - after the original broke.
kevsbox
10 Jun 2020
Portsmouth, UK
www.kevsbox.com
That is a very interesting solution which I will investigate because it would mean no need to replace and fit a new awerial. As per my photos my aerial is not a thin whip, it looks a little thicker. Does anyone know if wind vanes with these fittings can be purchased complete?
Refueler
13 Sep 2008
Blimey - just been looking at prices for a bit of plastic !! Not much cheaper than buying a whole antenna assembly !!
Since breaking my last one - I actually 3D print mine now ... the only part I have not managed to sort - is the V mount part ...
srm
16 May 2004
Azores, Terceira.
Alex_Blackwood
19 May 2003
Fareham
Rappey
13 Dec 2019
I Have a very nice powdercoated stainless steel stand alone wind vane that screws to the side of the mast. Its been extremely fat bstard seagull and his mates proof for the past 30 years and still looks like new.
I think mine is swedish but i found something similar (but not as nice) but since android has just updated i now cant find how to post a link. Grrrr
