Ian_Edwards
I need to replace the paddle wheel on the speed log.
The Airmar instruction say:
"If fouling is severe, push out the paddlewheel shaftusing a spare shaft or a 4D finish nail with a flattened point."
I tried this using a modified jeweler screwdriver, with a shaft about the same size as the paddle wheel shaft, I started gently tapping it, and finished up with a small lump hammer. I can get the side I'm tapping to move a couple of mm, but the shaft isn't moving on the other side, I'm just bending the plastic.
I stopped before I did any serious damage.
Has anyone else had this problem? If they have how did they get the pin out.
or any other bright, and printable suggestions.
