Removing shower waste pump on antarres 760
How do I remove shower waste pump on antarres 760 boat pump not pumping out water
Not a job I have had to do, yet, but I think that if you remove the hoses the plywood sheet that has the three pumps (shower drain, bilge and freshwater) attached can be removed as one big assembly so you can then work on any of the pumps.
Www.solocoastalsailing.co.uk
Easier I think to cut a new hole to gain access to the pumps then fit an inspection hatch cover into the hole, I’ve seen a couple of 760s with this mod. My shower drain doesn’t work although it doesn’t bother me, doubt I’ll ever be that desperate for a hot/cold/hot/cold/hot….shower anyway.
I love my shower which now has a repeatable and stable temperature thanks to the thermostatic mixer valve I fitted.
Hi I did think about that
Have you checked the filter isn't blocked? The clear dome unscrews and you can wash out the metal filter.
Or is it the actual pump itself?
Thanks for all your posts I managed to undo the 2 main screws that hold the board to the Hull where the pumps are located . I removed a few hoses which allowed me to move the whole board to the door are. Ordered new kit for pump as motor is working but would consider a hatch for the future. Thanks all
