Shower outlet pump spitting back.
dgadee
13 Oct 2010
Whale gulper 220 is slowly pumping out but spitting a lot back at some force. What might be the cause? Pump valves? Blockage in pipe before pump?
It is the in most hateful location to work on.
Yes, I have toilet troubles too. What happens when you take this apart. Does my holding tank empty into boat. Won't move.
https://www.forespar.com/pdf/techTips/M1-Marelon-Y-Valves.pdf
I think my heads has one of those that is difficult to operate. Just dread having to replace it as i have found servicing valves not really worth the agro. All the replacements I have seen have the outlets at slightly different angles so possibly involves new pipework as well :(
I was hoping if I took it apart then it would just be a solid mass of you know what from 6 months ago. Unfortunately I have used the tank twice ...
I will wait till the shower pump is operating then should help to clear whatever.
Lesson learned! Flush everything out of system before you leave the boat for a period.
My boat was new to me in December and the previous owner it would seem never operated peacocks. I can understand for the engine ones that are difficult to access but the others .....
I'm just going to have to remember to operate them every so often, possibly once a month.
I'd be awfully tempted to put a small dose of caustic soda down both, and leave it for a day or two
