Removing engine bay separation divider
Tearaway
22 Aug 2018
I'm a long time lurker but new member.
I've a 42ft steel motor boat with a inboard diesel engine under the floor.
The engine has plywood panels around it which are old and starting to rot.
Because of the panels it's very difficult to get into the compartments either side.
I'm thinking about removing them and not replacing them.
As far as I can see they're only there to reduce noise and my last boat didn't have them
Is there any reason why I should replace them?
Bouba
6 Sep 2016
SoF
A fire wall is always a good idea...except when they are made of wood...can you not engineer some steel bulkheads that are easily removable for engine service ?
My plastic boat is exactly the same...the engine bay is confined by dividers that creates two large crawl spaces port and starboard that I can no longer fit through and leaves the motor in a tight space that I can’t get to the other side of.
Greg2
24 Jun 2002
I wouldn’t necessarily write off wood. Mass timber has an inherent resistance to fire that can be enhanced by fire retardant chemicals.
Tearaway
22 Aug 2018
Yes, that's exactly my situation. The dividers seem to halve an already small space making it even smaller.
If I can remove them it would make the engine more accessible.
