Refitting duo props
PGD
9 Jul 2001
Thames - non tidal
www.peter-davey.com
Hi guys,
I took these off to send them away for a quick recon and now have come to refit them but something’s not quite right.
DPE drive year 2002
There is a splined spacer ring that seems to sit nicely in the back of the rear prop it also seems to stop the prop from wobbling. Then on goes the prop and prop nut, fine. Then on with the front prop, cone and centre nut, do it up tight and the props rub.
If you don’t use the spacer ring at the back then there is a nice little gap between the props but the rear prop seem to move side to side a little.
What am I doing wrong??
Did notice when I took it all apart the cone and the centre nut seemed loose, ie not much effort needed to get then off, maybe I'm doing it all up too tight.
Cheers
Peter
<hr width=100% size=1>Who gives the best service? tell us <A target="_blank" HREF=http://www.mssa.org.uk>Marine Service Standards Assistance</A>
Col
14 Oct 2001
Berks
There should also be another "splined" spacer before the rearmost prop.
<hr width=100% size=1><A target="_blank" HREF=http://www.arweb.co.uk/argallery/colspics> Cols Picture Album</A>
alastair
30 May 2001
Solent
www.javacharter.co.uk
The length of hubs on DPs can differ. Maybe your prop repairer didnt return the same props as you gave him to repair.
My advice would be to note the part Nos from both props, and ask Vovo if they are compatible.
PGD
9 Jul 2001
Thames - non tidal
www.peter-davey.com
hi, Steel Dev did the the recon job, deffo the same props came back as I marked them b 4 they went away.
PGD
9 Jul 2001
Thames - non tidal
www.peter-davey.com
Hi, please do I could do with the info, the chandlery wasn't to
good with the workshop manuals.
Peter
MLBURGE
24 Jul 2002
medway
Peter, where do you want it mailed to.
Its not a brilliant scan but you can see it ok.
this might be enough:-
The refitting procedure is - thrust washer - forward prop - screw nut 70-80 NM torque - thrust washer - aft prop - plastic washer - prop cone - washer and lock screw 70-80 NM torque.
martin.
