Reef line storeage
PabloPicasso
12 Feb 2010
We have reefing lines in the boom. They exit underneath at the forward end of the boom below the gooseneck.
Sometimes they end up in a mess on the deck at the foot of the mast, which is a nuisance.
How do folks keep their reefing tails neat by the mast. Do you use a bag, cleat them off, or another method??
Boathook
5 Oct 2001
Surrey & boat in Dorset.
I have sometimes put mine in the stack pack when I have put a reef in; failing that I try to coil them up neatly .... When not reefed the lines just hang down bit as they are 'cut' to fit.
johnalison
14 Feb 2007
Essex
I coil the lines and tidy them by self-tying or whatever it's called, so there is only a relatively small mass of line to stow under the sprayhood. Similarly with the tail of the jib halyard.
Nina Lucia
17 Jul 2005
We do the same, inside of stuck pack....
geem
27 Apr 2006
Caribbean
RunAgroundHard
20 Aug 2022
I just coil mine, put my hand through the coils, grab the standing part coming from the boom end, pull it through the coil, make a loop in the standing part pulled through the coil by twisting it on itself, then place this loop over the reefing winch at the back of the mast, below the boom.
It is secure enough for day to day sailing in brisk winds, but it doesn’t survive a pounding with big seas. A more secure coil is required. However, as a fast easy to do, easy to drop out, day to day coil, it is works well. All my halyards are stored like this but on cleats below jammers and are very secure.
roaringgirl
1 Nov 2014
Half way around: Wellington, NZ.
bit.ly
When I did RYA comp crew, the first thing I was taught was how to coil a rope. However, a traditional coil introduces a twist to the rope, which can stop it running freely when required. If those twists make their way into the boom, it increases the friction in the reefing system.
I *flake* spare rope at the mast, hols it together with a gasket-hitch and secure it to a mast-cleat by the free tail.
penfold
25 Aug 2003
On the Clyde
If the reefs are not taken in the ropes can be(should be? I would) trimmed so there are only 12-18" tails. On the relatively rare occasions a reef is needed just coil it up, although that dangly bag on the boom would be tidy also.
RunAgroundHard
20 Aug 2022
I disagree. A simple rope coil correctly performed removes the twist and kink risk. it doesn’t do what you say.
Daydream believer
6 Oct 2012
Southminster, essex
My lines are taken to the cockpit. I see no point in endangering myself to go on deck to make a reef. The lines are coiled & hung on Barton tidies. Halyards , being longer are couled using the gasket coil method shown in the link above. I see no point in stuffing lines together in bags as one pulled out means several pulled out together, creating a mess to be re packed.Furthermore, that mess can become tangled.
Line tamer
Poignard
23 Jul 2005
London and Brittany
Why would you be in danger working at the mast?
If the day comes when I feel unable, either through fear or infirmity, to leave the cockpit then that signals the end of my sailing days (at least as skipper of my own boat).
It's all very well, and extremely convenient, to have all lines brought back to the cockpit but if something goes wrong that necessitates you leaving the cockpit and going forward to sort it out, and you can't or daren't go, because you're not used to doing it, and there's no-one to go in your place, you are in one hell of a mess.
geem
27 Apr 2006
Caribbean
Line tamer
You criticise something you don't have any experience of. Par for the course I guess. I bet you are the tidiest boat in the marina
