Refueler
Osculati light arrived today ... very nice ... no silly press clip that gets harder over the years ... two sensible screws hold it together ...
Opened up to see internals ... has the required spiral filament bulb ... BUT 25W !! Swapped out for approved LED bulb and that should cut the ampage seriously !
Before the 'ekspurts' start - I am fully aware that CE certification means item + bulb .... Who's going to check once fitted ? As long as they see required Red / Green they'll pass on ...
I intend to swap out all my Spiral filament bulbs for LED's .... think on it .... Dual nav light 25W ( ... steaming light 10 or 25W .... stern light 10 or 25W .... that's minimum 4A + losses .. with possible 6A + losses if higher wattage bulbs fitted ... I can easily cut that back to about 2A ...
OK - so steaming light is only when engine on ... but still .. its a load that can be cut back.
