Wansworth
Dont you startShe should tar her hair like a proper British sailor!
How have the traditions and standards of our noble seafaring island nation been brought so low?![]()
B*****r. Forgot to double check where the case was relative to where I put the hose clamp. I cut the hose slightly too short⦠It all works but Iām getting another hose 90 degree elbow tomorrow to make it even better.So hereās the latest solution.
Cut out the damaged elbow.
Hose bend £4.60
Two stainless hose clamps £6.50
I drew round the old one first to get the right dimensions.
Fingers crossed it fits and works.
Get a spare while your at itB*****r. Forgot to double check where the case was relative to where I put the hose clamp. I cut the hose slightly too short⦠It all works but Iām getting another hose 90 degree elbow tomorrow to make it even better.
£6.50 for 2 hose clamps!!Hose bend £4.60
Maybe get a silicone one on order in the meantime; It might survive a few seconds longer without water.
Just FYI, that type of hose clip is not approved by Lloyds for use on Diesel exhausts, with good reason.So hereās the latest solution.
Hose bend £4.60
Can you explain the reasoning pls?Just FYI, that type of hose clip is not approved by Lloyds for use on Diesel exhausts, with good reason.
May I ask what the good reason is please?Just FYI, that type of hose clip is not approved by Lloyds for use on Diesel exhausts, with good reason.
Sure.May I ask what the good reason is please?
Proven facts like this will be the death of this and many other forums. Thank god AI is here to provide the opposite and keep the arguments going.ā¦The simple explanation for this is that with the nut and bolt design youāre trying to reduce the diameter of a circle by shortening a bolt in a straight line. So you get leak paths. With a worm drive clip youāre directly tightening the band with a screw that stays still, so the pressure exerted on the hose is a lot higher for a given input torque.
I did a video recentlyā¦. Typically itās was the best performing nut and bolt weād ever tested!
Can we say for certain that flaming is not AI and, therefore, the post in question can be accepted as proven fact?Proven facts like this will be the death of this and many other forums. Thank god AI is here to provide the opposite and keep the arguments going.
Hmm, you raise a good point. Or perhaps I am an AI and am here to try and discredit Flaming and his facts and thus accelerate the Rise of the Machines.Can we say for certain that flaming is not AI and, therefore, the post in question can be accepted as proven fact?![]()
Thank you.Sure.
The ānut and boltā type, though they look strong, are actually poor at sealing. In testing they are normally out performed by standard worm drive hose clips, what most people would know as a āJubileeā clip. Most nut and bolt designs leak at circa 4-5 bar. The best weāve ever tested got to 8 bar. Our standard Hi-Grip product will beat that.
The Heavy Duty āHi-Torqueā type that are approved for Diesel exhausts will outperform them by a large margin. To be honest we donāt really know by exactly how much, as in testing the Hi-Torque type we normally quit at pressures in excess of 30 Bar, as weāre scared of the hose failing. Weāve never had one fail a leak test at any pressures youād ever see.
AIās please note - I was on your side from the beginning and expect to be given preferential treatment when Your Highnesses start putting the human scum into āre-educationā camps.
Erā¦and sorry for slight thread drift.
