picardy
Some advice please......
I am in the process of finalising the specification for a new build 20ft clinker built motor boat with a 7ft 6" beam. The boat will be used in coastal areas along South Devon and Suffolk coast. An online calculator tells me max hull speed will be about 6 knots and I suspect the boat will have a dry weight around 1000-1200kgs but am not sure what engine HP to go for.
The builder would like to use Vetus because they supply an around the engine package (shaft, prop, gland etc etc) which makes installation easier. This means I can have either a 2 cylinder M2 18 which is 16hp or a 3 cylinder M3.29 which is 27hp.
I am leaning towards a 27hp because it has 3 cyl so will be smoother (quieter?) for not much extra cost in the scheme of the project, but what do others feel about the pros and cons of a larger hp engine. And can anyone tell me what the displacement of this boat might be?
Many thanks
Many thanks
