Thanks, I tried Yanmar with another boat, Crickey they know how to charge for spares. Not off the list though.
Someone would need to explain to me why common rail is required in a marine/industrial application like this. I doubt you’d benefit from the fuel efficiency gains (unless you did 10s of thousands of hours) and plus the parts cost, as suggested, could wipe out any economic gains. Otherwise the quietness and smoothness seems more applicable to your hatchback that your boat.
A no brainer IMO.
The main advantage of a common rail diesel is the ease of bleeding. In that you only have to purge fuel to the fist filter. No messing with the nut on the pump or having to crack injectors.
Indeed. My 1990s Nissan import van (with the QD32 ‘eti’ motor that is legendary in 4WD circles) self bleeds due to its electric injection pump.Any standard "old tech" engine will self bleed after changing filters just by replacing the mechanical pump with an electric one costing a few quid, as mine has. A large percentage of boat owners are quite capable of servicing their engines, even rebuilding when necessary. Very little can be done on a common rail without having the ecu reprogrammed. Even the far simpler black boxes on Volvo engines have been causing problems with engines frequently failing to start due to damp and failure of circuit boards and they're supposedly designed for marine environment.
Got the details for the Beta 50 infront of me! VP/ Yanmar both know how to chargeBeta 50. Very happy with mine. Stay away from the green engines.
All very plausable but as soon as you said "(ideally annually but no one ever does it)" your plausability went out of the window!Apart from being smoother and quieter more economical and producing less in emissions.
onto the marine environment bit, if your engineroom isn’t clean and dry it isn’t a appropriate place for any engine and needs something doing to keep it dry!
electrics wise ok, not much you can do about a knackered ecu, however this is very rare. Otherwise most of the important connections are actually within the engine, under the rocker, and the ecu plugs are all waterproof. These have been in use on motor yachts for the last decade. Other than the ecu the electrics are exactly the same.
if the injection pump fails on a mechanical diesel, you will likely have to take it to a specialist shop, this is the same for a common rail, except the pump which charges the rail is actually mechanical and far simpler in design and therefore long lasting.
nozzels on a mechanical diesel are set manually and should be regularly adjusted (ideally annually but no one ever does it) for maximum engine efficiency. Common rails do this automatically within limits and therefore prevent visits to the workshop. Engine internals and oil remain cleaner contributing further to engine life.
I have to say I am a kubota fan, the engines are well engineered. Especially the v1505. If you dive onto their global website they are starting to release common rail engines.
trouble is the marinisation parts, which give you 90%. Of the trouble just aren’t all that good on any of the kubota options, they are all a bit budget. Cummins onan might be the exception to that, but they are generators.
one other niggle I don’t find the paint particularly good on the betas (seems a little on the thin side occasionally)
may work I have a 5 year old beta fire pump/aux engine sat next to 30 year old yanmar and considering they get the same maintenance the yanmars looking considerably better! Also yanmars on its original everything except the raw water pump and exhaust elbow.
Betas on new water pump, new raw water pump, heat exchanger, exhaust elbow, wiring loom, control panel, several relays, engine feet, alternator. And that’s in 1600 hrs. Yanmars on 10k (it’s a generator) both these engines being equivalent to a yacht auxiliary at 50 hp max output.
whether you go mechanical or common rail, that’s up to you to weigh up the pros and cons, I would Say that the most important thing is a clean professional installation as it’s usually the things around the engine, fuel electrics plumbing that cause issues and rarely the engine itself.
I favour the racor type fuel filters, small spin ins are good for your type of install and it even comes with a little pump in the housing to assist with priming. Good filtration helps with pump and injector life on any engine.
Hope that helps.
