Raymarine's Micronet
Gixer
29 Nov 2015
Hello,
Is there any third party device that will talk to Raymarine's Micronet?
I'm thinking of a one box solution for linking to my ipad rather than T122 and quark wi-fi device.
Any ideas?
8 Aug 2016
On a boat
I don't think so. That would be awesome. The closest would be Raymarine's Micro-talk that is a Micro-net to NMEA2000 converter. Bear in mind that micronet tranducers will not work with a micronet display.
Gixer
29 Nov 2015
Thanks,
I'm surprised Quark or Marine Electronics haven't come up with something. I guess the protocol is locked or something.
prv
29 Nov 2009
Southampton
Seatalk1 is proprietary as well, but there are probably millions of devices out there using it, produced over thirty years or so. So there were people interested in reverse-engineering it, and a market for products using that knowledge.
TackTick instruments have always been a far, far smaller niche - and reverse engineering a radio signal needs extra skills and kit over a cabled serial link. So it could probably be done (assuming the data isn't actually encrypted, which I doubt) but it's not very surprising that it hasn't been.
DAVAIS
9 Jan 2019
Quark A031 is able to convert the old Seatalk messages into NMEA 0183 and then output via WiFi. This is the way I am using now.
8 Aug 2016
On a boat
Hmm, what does that have to do with Micronet though which is what the OP's instruments are? Micronet operates on 800-900mhz depending on where you are in the world. That is a long way from Wifi at 2.4 and 5ghz.
Gixer
29 Nov 2015
Thanks for the response, I was trying to find out is there's something else I could use instead of a raymarine T122 and Quark A to get data to my ipad but it looks like there isn't.
[163233]
13 Jun 2016
Micronet was developed when tacktick was distinct from Raymarine so the protocol probably doesn't resemble Raymarine's other proprietary protocols.
nrcoyle
4 Oct 2013
Dorset
I have been playing with receiving and decoding the micronet signal from my tacktick wind transducer as I am too tight to buy a T122, and I like hobby electronics. It is possible but I am still trying to iron out the protocol for decoding and that is only for wind. No idea what the signals from the other instruments will look like.
[163233]
13 Jun 2016
I'd be interested to see how you're going about it, because I'm also too tight to buy a T122 as well, it costs more than NASA's entire wind instrument and display.
nrcoyle
4 Oct 2013
Dorset
I had been capturing the transmissions using a RTL-SDR Stick that I had lying around to try and work out the parameters and encoding.
I have now managed to get some consistent output which makes sense for angles, still not sure about wind speed.
I need to get to the boat to test some more and hopefully build a simpler circuit with a RFM69 board I have, but then I should be able to put up the code and details probably on github.
Gixer
29 Nov 2015
Quick update from myeslf, I've managed to get a T122!
Next question is which Quark device to get for AIS receiving, GPS, Wi-Fi and output for DSC VHF..... I'm guessing the A026. More research needed!
[163233]
13 Jun 2016
Is it actually a digital signal?
I guess there can't be any encryption either?
bniester
29 Aug 2020
Did you ever make any progress with this? I am looking into this with RTL-SDR too but I have yet to figure out modulation technique being used by micronet. I tried with URH and GRC to demodulate and decode but no luck. If you could point me in the right direction, I have a PhD in signal processing that is willing to help me with this.. perhaps a collaboration??
Bill
nrcoyle
4 Oct 2013
Dorset
Still working on it, some details below of settings I have used successfully to point you in the right direction.
Modulation 2-FSK
Frequency 869.845MHz
Deviation 32 kHz
Bandwidth 250kHz
DataRate 76800 bps
SyncWord 0xb320 (Not sure if this is unique to my device or standard for all)
For the wind transducer you seem to get three sets of transmissions once a second,
A request from the display
Data from the masthead
ack from the display
I have focussed the decoding on the middle sentence, an example of which from my unit is:
413945c0415945c040212263030080a0a00001c080c0a006483ad72d6df4bacf4ccf5
for the wind sentences you get around 30 bytes of data,
I use the first 7 bytes to confirm the validity of the data. These bytes are always the same in the transducer transmission.
the wind speed data is between the 17, 18 and 19 bytes and is proceeded by hex 0a0a, decode by converting to decimal and dividing by 20.
The angle is in 2 compliments format and is proceeded by hex 0c0a for Left or positive angle or 0c0b for right or negative angle spread between the 23 and 25th bytes of the sentence.
Would love to hear any progress you make, and if you do manage to capture and decode any transmissions with URH, I would love to see them to try and understand the protocol further.
bniester
29 Aug 2020
A
Modulation 2-FSK
Deviation 32 kHz
Bandwidth 250kHz
DataRate 76800 bps
Awesome progress.. I'll let you know how I come along. I believe I made some good progress over the past couple days but I also think I recorded my signal with too much gain and got some signal cropping which is screwing things up. Going to try a re-record of the signal hopefully next week.
