Daverw
I originally did not have rudder sensor but found a way to add a couple of years ago, ice got tiller with no access to rudder post. What I did was fit the rudder sensor below in the void below and run a stainless cable ( cycle cable) to it through a ptfe cable tube, this came out just next to the tiller post, then I wrapped it round the top of the rudder post, when I turn tiller to port this pulls the sensor up and as the raymarine sensor is sprung return this keeps the cable tight for turns to starboard.
Very simple and just works, not effected by lifting tiller up either.
Now I’m just about to fit the b&g sensor which is not sprung return and will have to add either bungee cord or spring. I have not had time to test if the raymarine sensor will actually work with the nac2 as this can also take an analogue sensor
