Leighb
In early June the engineer who had done our work over the winter noticed a leak from the raw water pump. The pump was removed, new seals and bearings fitted and pump refitted.
Yesterday because of overheating at higher speeds on that engine, a different engineer started his investigation by removing the raw water pump to make certain there was no excessive wear as part of the cause of the overheating.
On removing the pump he found this!!!!
On further dismantling the pump it was found that the other ball race had also lost half of it's balls!
Although unrelated to the overheating what possible reason could there be for new bearings to break up like this? The engine has run for about 55 hours since the bearings were replaced and only around 2400 RPM because of the overheating. Result is I need a new pump as the breakup has caused a lot of scoring internally.
Not happy.
Not happy.
