Leighb
A minor further update. It so happens that for reasons best known to themselves the "first" engineers bought 2 sets of seals and bearings, and gave me the "spare" set for future use. I have brought them back from the boat and had a look at them. Having done a careful ball count it would appear that I have not lost any balls. That is a relief.
The new bearings each have eight and there are eight remaining in the damaged races, what has at least partly disappeared are the cages that hold the balls apart So no balls have disappeared into the depths.
Also in answer to a query raised, the new bearings are in sealed plastic bags marked SKF 6203. The seals have markings MFC Tc 16 28.
Dragoon, there are definitely 2 seals, back to back between the impeller side of the shaft and the bearings. One presumably to keep the salt water out and the other to keep the oil in.
I have changed engineers, and as I said in my post I owe the other lot for their last lot of work, so deductions will be applied. There may of course be ructions.
A new pump has been obtained and is to be fitted on Monday, hopefully we may be operational again before too long.
