jlavery
Hard 63 miles to windward yesterday from Gairloch to Mallaig in 18-25kts. Motorsailed for several hours initially to get through the chop.
Started engine approaching Mallaig - no raw water. SWMBO had a sense of humour failure. Used engine sparingly to berth.
Opened up pump to find... no impellor at all!
The bolt holding the internal cam in the pump had failed, allowing the now loose cam to shred the impellor!
All the debris ended up on the sea-side of the pump, not the heat exchanger (I've checked).
Very glad I was carrying an entire spare pump on board! Fitting it now (although need to acquire a gear puller to get the drive gear off the old pump).
