QBhoy
Flow rate it definitely a concern, I’d think !Flow rate isn't a concern actually, as the flow rate doesn't change. On mine, there's a pump that takes sea water and pumps it into the exhaust, and a separate pump that takes the sea water and flows it through a small heat exchanger, and then out of the exhaust. There's a thermostat which swaps power to the relevant pump, and is seamless. When the engine's operating at power, the power to each pump is swapped more frequently than when it's idling.
The relay's auto standard (rugged/available/cheap), the thermostat is also 'auto' quality, with the sensor being in the fresh water header tank.
Originally, the engine had a mechanical thermostat, which IS the work of the devil, designed to clog and fail by virtue of its operating temperature with salt water!
The heat exchanger is 22kW, with a thermal shock to the engine coolant being about 5°C depending on which cooling pump is running, with the temperature peaking to 35°C on the exhaust when the 'heat exchanger' pump is operating, otherwise it's at about 19°C when the exhaust cooling only pump is running.
The exhaust temperature alarm is set at 50°C, which then lights up an LED, and gives an audible alarm.
Having warm salt water running through an engine is one that's suitable for the manufacturer, not the user. I'm aware that many engines are already fresh water cooled, but I didn't have that option, as to rig a 2nd mechanical pump for the fresh water engine coolant was far more complicated for me.
