john_morris_uk
You’re making assumptions about the accuracy of the charting that is sometimes unwarranted in waters outside Europe.GPS might not cut it, but a Chart Plotter does.
Not really, a chart plotter tells you what should be there, not what is there and that’s assuming everything is up to date and set up correctly. The rocks don’t move...unless you set the geode wrong. If it’s truly dark (and the lochs can be very dark indeed) then useful to have something showing what is there rather than what should be there in theory. More so given that the canyon like nature of a steep sided loch reduces gps accuracy. It’s the difference between proceeding with extreme caution and proceeding with confidence. Obviously you’d use the two together for the reason of underwater rocks mentioned above.GPS might not cut it, but a Chart Plotter does.
Is that relevant?How do you know Cheeky Girl is a ‘she’?
True, but that means either you need two people on watch or do what we do and have the radar screen visible from the companionway.
It strikes me that people choose to praise or lambast navigational aids just to re-enforce their argument of the day!
How did they not know? Wasn't it obvious?I've actually crewed on a boat where the owner didn't know he had radar.
Each to their own. I enjoy sailing the boat but I rarely steer by hand. Having the plotter and radar below is no hardship and we usually keep a plot of some sort going on a paper chart. I’ve seen people so glued to the plotter visible at the helm that they forget to look up. I’m sure you don’t fall into this trap but for when we want pilotage info instantly I use Navionics on my phone or we have the facility to use an iPad as a repeater of the main Raymarine display below.I have never understood why so many people have radar or plotter down below where they can't be seen from the helm. Everything we need to see is under the sprayhood.
You’re probably right. But a good navigator uses and cross checks all available information. We entered New Grimsby Harbour (Scilly Isles) a few years ago in the pitch black. It’s completely unlit and I was using plotter, echo sounder, Navionics and Radar to cross check that we were ok and safe. It’s very eery closing a rocky coast hearing breakers all around and entering a narrowish inlet with cliffs/hills either side in the blackness. Radar and GPS and sounder all agreed with the charting so we were safe.It strikes me that people choose to praise or lambast navigational aids just to re-enforce their argument of the day!
When I suggest that a CP gives a better representation of what is around you than just using GPS (and presumably a chart) I am told in effect that the drawings on a CP and chart are almost a figment of some cartographers imagination, and that the GPS signal from the Sats are so badly degraded that they can't be trusted. How wide are these Lochs and how tall are the banks that would cause this to be a problem?
I agree that the display on RADAR of the sides of a Loch are impressive, but when the Loch gets so narrow that the other aids output are suspect then I could equally use a torch to see the sides [tongue in cheek].
Or even within Europe in regions where the sea-bed is mobile, such as the bars of rivers like the Deben and Ore, or estuaries such as the Humber.You’re making assumptions about the accuracy of the charting that is sometimes unwarranted in waters outside Europe.
My radar works well but struggles to see the sea bed.Or even within Europe in regions where the sea-bed is mobile, such as the bars of rivers like the Deben and Ore, or estuaries such as the Humber.
It must have been my naval training that meant in the first two weeks of ownership I crawled round on my hands and knees establishing what everything was!Not surprised, some people are clueless. On another forum, a guy was asking where his holding tank was likely to be and where the galley seacock was located. He'd only had the boat for seven years!
I agree. But the absolute confidence that some people seem to have in their plotters and it’s electronic charting is still worrying. I suggest that everyone who goes aground in a catastrophic unintended way thought they ‘knew’ where they were. Quite often by believing what the plotter says without either looking up or looking at all the other data (like the echo sounder) that’s in front of them. But I am drifting the thread.My radar works well but struggles to see the sea bed.![]()
But in the areas I mentioned, the banks are uncovered at half-tide, and also show distinct scattering patterns even when covered. I've had the opportunity of seeing the latter effect in the Humber from the bridge of a research vessel moored in Hull docks - the pattern of the shoals was more evident than the return from a coaster in the river!My radar works well but struggles to see the sea bed.![]()
So you reckon that you can detect a shoal on radar from the change in wave pattern or lack of? I can't say that I have ever tried but it sounds like an interesting exercise next time I get a chance. I can think of some of the Belgian banks that would give a good return but our local ones are more like ripples.We are on the Humber and agree that the mud banks just under show up as surface patten quite often
