Bosun Higgs
N/A
A full half turn on the wheel also doesn't sound great. The ideal rudder angle upwind is 5 degrees. .
You are meaning angle on the rudder not the wheel arent you? I'll have to measure that
Which implies you sheet the genny to a certain point and then sail to it. But what is that point? Do you trim to where it touches the spreaders?
I always helm by the tell tales. I take your point about skippering - just a bit nervous of anyone else helming my P and J in the starting melee.
Er - no - I don't race the big boat - just dinghies - where unless it is blowing dogs off chains the JIB is pulled in to the desired point and cleated off - the helm then sails to that - the faster guys probably do it differently and don't cleat the jib - but then I've found I'm hunting for the right angle to what is being steered and the helm is hunting for the right angle for the jib - a circular reference!! Oh - I don't have a compass onboard the dinghy either - so can't sail to that!Which implies you sheet the genny to a certain point and then sail to it. But what is that point? Do you trim to where it touches the spreaders?
Heh - I know what you mean ... I crewed for Dad in his boat - so no issue - I just balanced the boat and called the time up till the start gun - well - last 30 seconds I'd be calling out a bit more - even got the whole fleet OCS in one race because we were early and it was round the ends for restart ... no thanks!!I always helm by the tell tales. I take your point about skippering - just a bit nervous of anyone else helming my P and J in the starting melee.
Anway, anybody ever been to a racing school? If so was it worth it?
Phoned them earlier on this afternoon Gruff!
Another thought. We assume you are talking about pure boatspeed here when hard on the wind rather than effective VMG overall to the windward mark because first one there wins usually. VMG brings in other factors like tack speed and speed recovery after a tack and tacking on windshifts and staying in clear air and..
The consensus based on the info I have given seems to be that we were over pressed so I will try reefing a bit earlier next time and reefing the main first. Still not sure however since we never rounded up. The First 31.7 we were reaching alongside had full main and what looked like a no2 up. He did round up despite 5 blokes on the rail but still left us for dead upwind. He has same LWL and near enough the same PY.
yes, pure boat speed / pointing. By the time we got to the beats yesterday, there was a fair bit of space between the 14 boats in the fleet - we are handicap racing and the speed range is maybe 15%. We didnt tack on windshifts and I'm non too sure that with our tacking speed it would be worthwhile unless the shifts were fairly big and fairly long term. We dont tack on a sixpence.
I take care to go smoothly through a tack rather than simply put the wheel hard over. If I dont, the guys on the winches complain!
Try measuring how much you loose each tack in boat lengths. Two is fine, five is poor, more is bad, but maybe given you're racing a heavy cruiser you can accept worse. Still most times you'll gain significantly using windshifts. Try calculating it, you'll surprised at the results.
OK, you can train to tack more efficiently but many boats lose most coming out of the tack. They don't focus on accelerating out of the tack so oversheet and take much longer to get up to speed.
With a fin keeled boat you go to windward better when you're moving faster, so bear off slightly after the tack, ease the main slightly, don't sheet in the last inch or two of genny sheet until you're getting back up towards you close-hauled speed then you can go close-hauled and flatten the sails. The little extra belly and twist in the sails coming out of the tack helps you accelerate.
And I bet that was just for eating the lunch on the rail ....We got silverware.
Oh blimey - one of those racers ... where you're allowed 5ml of water per crew member and 1 square of toilet paper - shared - all to save weight!!
Still makes me laugh when people down the ranks do similar things - trying to tune their rigs to the nth degree and put all the 'go faster gear' on ... when actually just sailing the damm thing properly would help far more ....
I suppose if I got out and did some practice I could get better - but it's just fun for me ...
