C_Harkness
Pretty much as the title suggests really, I'm looking for an adhesive to bond strips of timber to a fibreglass internal wall. Google has brought up some ideas but it seems they're either very expensive, or will take way too long to set. The job is a vertical (ish) wall and a lot of the glues suggest holding things in place for 24 hours, my arms will be the only thing I can use to hold against a wall - clamping is impossible, and I don't fancy spending 24 hours holding it if I can avoid it!
Suggestions I've seen so far are 3M 5200, which looks like it will be a very expensive route for covering a very large area, No More Nails which recommends waiting 24 hours - I assume Gorilla Glue and other similar adhesives will be the same, and Sikaflex.
Any suggestions of something quick and easy that will happily adhere to both wood and fibreglass quickly and not require holding in place for extended periods?
