fletchernewbie
New Member
Hi,
I'm new to the whole boating scene and need some help please. Excuse my ignorance of boating and the silly questions below but I would appreciate your advice very much.
I have a fletcher arrowsport speed boat.
Boat leak - The last couple of times I have had the boat out the bottom compartment (where I store my skis) takes on a lot of water. So much so that the carpet is getting wet. So today when I had the boat out of the water I filled this compartment with water from the hose because I suspected that the very bottom of the boat was leaking in water. I was able to see that it was dripping water at the bottom.
I think the bottom of the boat has been damaged because it hasn't been sitting properly on the rollers of the trailer (but rather to the metal bit at the side).
How can I fix this? What should I do to repair this?
Bilge pump - I do have a switch on the dashboard for a bilge pump but I'm not actually sure if one is installed on the boat / or if its work. I presume if the boat was taking on water I could use the bilge pump? I looked inside the compartment but couldn't see any 'pump' but that does mean there isn't one outside of the small compartment, in the wider section.
How can I check if I have a bilge pump and that it works?
Can I turn it on without starting the outboard?
Two batteries - Why do I have two batteries on the boat – Sorry for the silly question! I have one battery at the back left and one at the back right. Could one be for the bilge pump??
Many thanks for your help – it is much appreciated. And again, apologies for the simplicity of the questions.
Gordon
Gordon
