steve yates
If you just switch on a tricolour, is the white section supposed to be your stern light?
in which case you would need a separate steaming light?
I presume thats the case, but then the white light is in the wrong place for a stern light surely? And If its a steaming light, then how can you choose not to show it if you were under sail at night and switched it on to show your nav lights?
The reason I ask is my tricolour got damaged last eyar when the mast was down by another boat, and I forgot about it, so the red and green sections have been knocked off. I remembered after connecting it all up and seeing an all round white light at my masthead
So it seems to me the simplest solution is to add seperate nav lights on the sides and stern of the boat, where the old knackered ones are, so just replace them with led ones. That leaves me with an anchor light, albeit an incandescent one, which prob isnt ideal in the power draw stakes. I know they are generall better low down and I usually hang a battery one from the boom, but its an 18 foot boat, so the mast is not exactly high up in the sky.
Can I use this all round white at the mast head as a steaming light if motoring at night? Or does it HAVE to be invisible from astern?
I note the colregs say a tri colour must be visible to 22 degress abaft the beam.
I do have another tricolour I could put up, but its going to be a long time before I have access to the top of the mast again, and im not married to the idea of a tricolour up there anyway.
