tymonk
Hello,
I recently installed a PV Logic dual battery MPPT controller, prioritising the domestic battery which it charges to 70% and then is meant to charge both batteries simultaneously. The manual states: "Please note this battery [Battery 2] must be on a separate electrical circuit and not connected back to 'Battery 1' in any way." It doesn't provide any warnings about what may follow if this happens.
Having left the boat on its swinging mooring last weekend, I now at home realise a small oversight. There is a dual sensing VSR (connect at 13.7, disconnect at 12.8). My fear is now that the if the solar generates a sufficiently high voltage the VSR will engage and I do not know what will happen then. Could it be that the controller simply won't charge properly, that it will damage the controller/batteries, or something worse...?
Fortunately the 2 panels are not big at all (a 5W panel and an unrated panel that came with the boat, that cannot be much more than 10-20W). My hope is that especially with it not being very sunny the controller will struggle to deliver over 13.7 anyway.
I'm due to go abroad for work tomorrow and wondering what the worst is that can happen and whether I need to see if I need to go back to disconnect Battery 2 (starter) from the controller. Ideally looking for some reassurance that it will probably be fine to leave for a couple of weeks
Thanks in advance.
Thanks in advance.
