bajo
I am here trying to get some info for a friend using this wind vane on a Contessa 26, if anyone had or has the necessary know how to get the best results from this vane,it would be most appreciated.
I have used one: does not generate much power to the tiller lines, especially offwind, so you do need to balance the sails well. Especially offwind, the course was always a bit S-shaped, though it did work.I am here trying to get some info for a friend using this wind vane on a Contessa 26, if anyone had or has the necessary know how to get the best results from this vane,it would be most appreciated.
Agree, it's an absolute must for any vane gear.
The QME is a mechanically very simple device, but the pull it can generate on the tiller line is limited by the fact that there is no water-paddle servo action - pull to the tiller is created only by lift/drag from the air vane. It was very cheap though when first built.Incorrect.
This comment can be a little misleading
In fact i bought my Aeries because of the heavy helm on my boat . The Simrad TP32 cannot cope in heavy weather
With the Aeries If you try to hold the control line against the pull of the steering oar you would find that a grown man could not pull it for long. In fact if the boat is moving over 5 knots one cannot hold it against the pull at all
It is a myth that you need a balanced sail layout with a good gear like the Aeries.
However, I have no experience of the subject vane so that may be the case in poorly designed vanes
Once you make the windvane control a water servo paddle a la Aries/Hydrovane etc, you gain lots of power.
Well not quite, the Hydrovane isn't a servo pendulum unit. It simply uses the force generated by the airvane to turn its own self contained auxiliary c.
Incorrect.
I had one in the late 70's and only got it to work successfully twice over about 5 years despit much trying. For occasional use I'd recommend a Tillerpilot or similar, otherwise it's a servo system.
I found a significant improvement to how my Aeries worked when I applied a glass fibre reinforcing to the vane to make it stiffer.
Surely that is because you made the vane heavier not stiffer. Some folk got the same effect by squeezing a pair of vice pliers onto the vane. Right at the top for light winds and then moved down the edge as the wind increased.
Could get the same effect by reducing the balance weight but with no easy adjustment
>In fact i bought my Aeries because of the heavy helm on my boat . ..It is a myth that you need a balanced sail layout with a good gear like the Aeries.
If you have a heavy helm then the sails aren't balanced. I can't see why an Aries would be any differnt regarding balanced sails than any other vane gear.
I used one from '74 to '76 when sailing a 26ft trimaran to and around the Med. It helped trim the boat to self steer to windward and on a beam reach. Downwind you needed a full gale! Don't expect too much.
