TerryA
Active Member
Toilet compartment has a hand held shower with a hose that pulls out between the two mixer taps. When retracted the shower head sits on a washbasin and is used instead of a tap. There is a leak somewhere behind the panelling that flows into the shower tray. I changed the freshwater pump today so the improved pressure at the taps has really aggrevated the leak, one step forward two back as usual. I'm used to domestic type shower hoses that screw on above mixer taps but not hoses that retract so the head can fill a basin. Before I get the plumbing kit out and start removing panels I'd like to know how the set up works. Is the hose simply fitted to the underside of the mixer taps and loops back up or is there something more complicated. It's original 90s stuff so wierd wouldn't be surprising.
