Greg2
I am going to swim against the tide a little inasmuch as I don't share the same concerns as other appear to about osmosis / moisture content in a hull. The yards are right in saying that properly treated the boat will be better than others on the market (probably better than when it was new) and it will be a known quantity if the work is properly documented by a surveyor. I would though, seek a price reduction to cater for the fact that common perception on the part of a future buyer is likely to be ill-informed in much the same way as people generally seem to think that low engine hours are always good and high hours are always bad.
On the matter of cost, it is worth considering what is actually involved, which is peeling the gel coat with a machine, hard standing for several months with regular jet washing of the hull and then the application of epoxy. That doesn't get anywhere near £30-40k to my mind and I know someone who had the hull done on a 10 metre boat for circa £15k by a respectable yard so it sounds as though someone might be inflating the cost although that might be on the basis of applying heat, which I was advised by a competent yard and separate respected boat builder is not necessary (described as a waste of time) and that time on the hard (circa 6 months) after the gel coat has been peeled is what is actually required.
I do understand why many are saying walk away but to my mind understanding what is involved, what the deal is and understanding whether you are the type of person that is happy to take on a challenge are key factors.
