Probably a silly question - headsail sheets
14K478
15 Aug 2023
I adhere to the rule that headsail sheets should be blue. But having replaced one sheet due to chafe I now should replace the other. It has been quite handy not having the port and starboard sheets identical, but it looks odd.
I can replace the other sheet (14mm Dyneema with a braid coat) with the twin of the first one, or choose a slightly different form of blue, What would you advise?
johnphilip
15 Nov 2005
I have found it useful to have different colours. When on the foredeck poling out the jib a call back to an inexperienced crew to " pull the red one" or "release the blue" adds clarity.
14K478
15 Aug 2023
When I started sailing you could have any colour you wanted for halyards and sheets, as long as it was brown, you bought it by weight. you turned each line end for end at the end of a yard and replaced the lot at the end of the second year!
arc1
28 Jul 2020
I have all the same colour for loads of lines as buy them in sale as job lot - whilst cheaper, not without it's issues when sailing with friends, especially non-sailors!
14K478
15 Aug 2023
Don't ask me how I know this! ;)
johnalison
14 Feb 2007
Essex
It has never bothered me, though I like main and jib to look different, plus the rest. The only thing I need for my jib sheets is that they should be ‘shiny’ as I have found that the matt ones don’t pass the shrouds so readily, even with rollers.
justanothersailboat
2 Aug 2021
If you have a bunch of lines to replace, it's usually cheaper to buy a whole spool or two from a rope factory rather than lots of individual bits from chandlers. Sorry chandlers. If you have labelled clutches and sew a bit of different coloured string through each loose end it's not likely to result in confusion.
Fantasie 19
23 Mar 2009
Chichester, West Sussex
You live and learn - that's the first time I've heard there was such a rule..
oldmanofthehills
13 Aug 2010
Bristol / Cornwall
Seems a remarkably foolish rule to me. In the old days all ropes were brown, and the moment synthetic ropes came along people sensibly made them in various colours to enable ready visual differentiation
As an engineer adhering to CDM I flinch at the idea of deliberately increasing the risk of confusion by trying to half mimic a more primitive system
Neeves
20 Nov 2011
Sydney, Australia.
This concept must be new, or 'relatively' new. Sheets and all cordage used to be brown, or maybe straw coloured (and now if you have a 'traditional' yacht you will buy synthetics in the same sorts of colours to match your, genuine, CQR (with the real anchor concealed in a bow locker).
I'm too young, and hence impocuneous, to know but surely the next move was to all white polyester, unless you were flush, thus from south of the border, and it had a coloured fleck in the cover.
Changes then moved rapidly and we had flecks, commonplace and then solid colours - but surely solid colours were 60s or 70s hardly enough time in 'yachting' for it to be a rule (unless you came from the Home Counties - in which case everything had to be blue). Presumably Scots yachts from Glasgow had a different rule and everything was red, not blue. I could imagine Mt Heath would have been keen that 'working' sheets should be blue.
When Dyneema became more common place we bought reels of solid coloured rope and what we did not use, which was a lot, went to other X-99s.
Odd how 'rules' might develop.
Jonathan
14K478
15 Aug 2023
See Jimmy Green website
Headsail sheets and halyards blue, spin sheets and halyards red, red, mainsheet and main halyard white, topping lift three strand. guys red and white, staysail sheets and halyards blue and white. Different colours for reefing lines 3 red, 2 blue, one green iirc.
14K478
15 Aug 2023
Jonathan
See my post 5 above. And 17. Yes I started with manila - lightly tarred. Yacht Grade for racers and Number One for hoi polloi like me. It came in "inch and quarter" or "inch and a half" and you bought it by weight.
Four strand tarred hemp for shroud lanyards and buoy ropes ( you picked up the buoy and took in on board and hauled in the rope to find the chain, which you made fast round the Samson post with a lighterman's hitch
Then we went to whilte Polyester three strand. Plastic buoys came in about this time.
The Youth of Today fret about marinas - what was a Marina? ;)
DanTribe
8 Jan 2002
Essex
I've had boats for a few decades but never heard of the blue sheet rule.
I use continuous sheets cow hitched to the clew to reduce the bulk of knots.
Boathook
5 Oct 2001
Surrey & boat in Dorset.
Seems to be suggestions from Jimmy Green.
When I sailed on a new boat in the 70's all the sheets were white and quite a few had the Marlow black fleck.
I now use any colour depending upon price, etc.
