That would depend on what grade steel was used, how it was tempered, and how it was galvanised - surely? ?????The "Fisherman's" looks a bit bendy to me. (Here goes another anchor thread)
And for whether it is meant to do more than holding station while the crew angle for fish?That would depend on what grade steel was used, how it was tempered, and how it was galvanised - surely? ?????
I think there may be more to that grapnel under closer inspection . There is a ring around the base of the prongs. Could the ring move up and down making it fold or open up ?Not happy with his grapnel
I’ve now seen a lot of other examples in local marinas. All on small fishing boats. There must be some technique that they use which involves its use.I think there may be more to that grapnel under closer inspection . There is a ring around the base of the prongs. Could the ring move up and down making it fold or open up ?
Looks like a rusty bit of rebar to me.That would depend on what grade steel was used, how it was tempered, and how it was galvanised - surely? ?????
Thank you for the explanation. That makes perfect sense.The grapnel looks similar to what the fishermen here use - here these anchors are called 'creepers'.
The prongs are usually rebars, or varying thickness, welded to a solid round bar shank.
Or sometimes the 'shank' is a length of plastic pipe filled with concrete, and the prongs are cast in it.
These creepers are used for bottom fishing in (very) deep water - if the anchor fouls on something (very likely), then a touch of throttle on the engine will bend the snagged rebar(s) and allow the anchor to be retrieved.
All they have to do then is to put some bend back in to the fluke(s) before anchoring at the next fishing spot.
So now the utility/longevity calculation has to take fatigue strength into account!The grapnel looks similar to what the fishermen here use - here these anchors are called 'creepers'.
Quite common here too, they are sometimes sold rolled in paper with all the prongs kept straight, the buyer then applies the amount of bending he deems appropriate, apparently one of the well kept fishermen secrets.The grapnel looks similar to what the fishermen here use - here these anchors are called 'creepers'.
