Geoff34
I have a Princess 25 which I use on rivers at around 5 mph. Unfortunately I have to constantly tweak the steering left and right to keep it going straight. Any suggestions to correct this?
Put ballast in bow you can experiment by putting crew ut bow first.I have a Princess 25 which I use on rivers at around 5 mph. Unfortunately I have to constantly tweak the steering left and right to keep it going straight. Any suggestions to correct this?
I’m guessing it’s got a single engine and outdrive?Put ballast in bow you can experiment by putting crew ut bow first.
See my earlier post it is easily cureableI’m guessing it’s got a single engine and outdrive?
If so……….I’m afraid it’s always going to lack directional stability at very low speeds.
There used to be ‘rudder plates’ that you could bolt onto single outboard engines to solve similar ‘wandering’
problems. Not sure if they would fit an outdrive?
Ballasting the bow works well on the river but not wise for sea work.My first proper boat
A little beauty, well constructed mine powered by a VP V6 175 HP? petrol with single 280 T outdrive, used both on non tidal and coastal waters.
At full blast it could with the wind behind it get up to nearly 17 knots.
It is a problem with all/most outdrive boats especially at displacement speeds to need to have to constantly keep an eye on the heading especially in breezy conditions.
Personally thought my P25 did not suffer unduly from this compared to my later P33 and other outdrive boats.
Things definately improve a little once the boat goes faster.
Adding ballast to the bow might result in a completely different set of difficulties.
Crew standing on the foredeck did cause the boat to become difficult to steer, possibly as the outdrive rose to the surface of the water ?
ThanksI’m guessing it’s got a single engine and outdrive?
Hi it does have a 3 position leg, However I was told that the adjustment was only if you were having problems at high speed due to engine toque. Might be worth a try!!Assume the outdrive is a 270 and no method of trimming outdrive leg.
On my boat with the 280 T it was possible to trim the leg .
Hi Geoff.Thanks
