KREW2
I am in the process of fitting a 1000 amp windlass. I have decided to run it from a separate battery in the forpeak, so as not to have to run 50mm2 cable. I have 2 x 110amp hour batteries on a 1, 2, both switch I know they are leisure batteries but I intend to use one for starting, and the other as a leisure battery. I'm going to buy a starting battery for the windlass, and charge it by connecting it to the designated starting battery.
My question is, as these 2 batteries will be in parallel I assume when I start my engine it will draw power from both, will I still be able to run a lighter cable to the windlass for charging purposes.
