scottie
Maybe time to start the post again
Engine does not give full power after x years without use perhaps ?
To summarise - certainly not a slipping gearbox.
The other things to check:-
1. if the exhaust elbow is blocked, usually cleaned out every 1000 hours. Take it off and clean it out.
2. Lack of compression due to worn or sticking rings. Have a compression test carried out.
3. Overpropped. put on the old 2-blade propellor.
Worn oil seals or guides are just a red herring - put up lubricating oil use.
However - if I understand that your sump seems to miraculously fill itself - its definitely broken rings.
Apologies if this has been suggested before as I haven't read the entire thread but in post #15 you (Robert) mention a change in prop blade to hull clearance due to perhaps not clamping the shaft as far back in the coupling as before.
Is it possible then that under thrust, with the shaft being slightly further forward than before, the forward face of the prop boss is now contacting the aft face of the cutless/shaft log/P bracket (whatever you have..) and that you are getting losses due to friction at that point? The shaft would spin freely by hand when unloaded but when the engine mounts flex under forward thrust extra drag would be introduced.
Probably a stupid suggestion but I thought I'd throw it in there.
when the engine/ boat was laid up, did you plug the exhaust outlet? It's common to have whatever exhaust valve was open to develop corrosion on the seat and valve face in a damp atmosphere ( eg Scotland!)
Simple answer is "no".. Another reason for removing the lump this autumn.
Is the engine firing on all cylinders? Crack open the injector pipes one at a time while running at idle, the rev drop should be equal if each cylinder is doing its share.
It's a two cylinder donk and I did just that yesterday. I didn't do it to assess the "equality of drop in revs" but I wish now I had read your post before!
From memory I think they were equal but I didn't run them long, just long enough to check for fuel squirting/dribbling through.
I'll do a proper check at the next visit.
Not today, it is not only Sunday (Sabbath) but it's blowy and driech (miserably wet for those who haven't heard that delightfully descriptive term for gloomy, misty and bruddy wet!)
Maybe drain the exhaust water lock too when laying up..
Is there a simple way to do that? Genuine question.
Richard
Many waterlocks have plugs at the bottom for just that purpose, including the popular Vetus types.
If the engine has done more than 8000 hours it's probably least tedious to replace it.
I think mine is a Vetus watertrap but I've never noticed any drain plugs. I think mine is plastic or GRP rather than metal but I've never looked at it that closely.
Gee, thanks
That advice is directly proportionate to the crap weather up here today made worse by listening to reports of the continuing "Mediterranean" weather over the rest of Britain.
