Robert Wilson
The high pressure pipe is the one that goes from the pump to the injector, usually entering from the side, the return is the one on the top.
A quick test would be to loosen the HP pipe connection and see if it leaks fuel in spurts. If so, then remove the injector and refit the tube with the nozzle facing away and retest. I repeat, do not have any skin anywhere near it as the very high pressure can blow fuel through into the bloodstream and cause severe probs.
I will have a look for pics of the engine.
Looking at Google pix, I might be wrong on the placing of the pipe, it could be the one on the top of the injector. Just follow them from the pump.
Gotcha, thanks.
I thought that was it, but just wanted to make sure.
There is also an odd little rubber pipe/hose which comes out of what looks like a bleed tap atop the injector pump.
This pipe/bleeder is attached to a union where the fuel inlet hose from the lift pump enters the top of the injector pump
and goes into the side of one of the injectors. It's only on one injector.Any idea what this might be and how it might affect fuel supply?
I'll try to post a pic, but I have trouble with the technology!!
