pcatterall
Considering my solar requirements again! Spain 10m ketch.
Currently we have about 100 watts on stern fittings plus 2 small ( 20watts each ) on the dog house roof.
I have started leaving the boat long term with electrics off and just the small units topping up the batts.
Cruising we have auto pilot and small waeco chest fridge plus lights and instruments. ( and all the dam mobile phones that the crew find indispensable
With care we can be self sufficient under sail ( but sometimes hand steer to reduce the load)
We are considering getting 2x 100 watt semiflexible panels which we can use on or off a backing board and mount on rails or other suitable spots when we are moored (or even cruising 'serenely').
We may fit a power socket somewhere centrally on deck so that the panels can be connected by a trailing lead ( yes trip hazard!) ( there is a live outlet near the bow which could do but I need to check the cable size)
The panels could be stored flat on a berth under the mattress.
so...… I will appreciate general comments and suggestions but specifically would like advice on cable size for example a 10m run with max 200 watts load. I can use the sizing chart but what would be a sensible compromise in % efficiency?
Also what is the practical difference between mono and poly units.
The usual thanks!
The usual thanks!
