Boo2
Anyone know where I can find the polars for a UFO 34 ?
Thanks,
Boo2
Thanks,
Boo2
I'd say that with old boats (especially, but also true with new ones), it's better off going out and playing, and making your own will be better than taking someone else's.
Circa 1973 polars won't account for changes in rig and sail tech, and they will be based off the weight of the boat then, which may well be different.
There's a few apps out there, but I'd imagine quality of data is proportional to cost.
The other option is to get in contact with these chaps and look at the polars they calculated for other boats (although be sure to look at their sail areas, type of kites carried etc).
If you use others' polars, make sure your instruments are calibrated as well as you can (or can afford), otherwise you won't be getting good TWS/BSP data with which to compare to the polars.
Boo has carried out extensive an extensive re-fit & mods, extra tankage in the stern, so Polars will be way outProblem with making your own polars is that you are limited to your ability and your equipment. So you can be sailing along at 100% but not realising you're not fulfilling the hulls true potential by not trimming the jib perfectly or by having a knackered main or a slightly grubby bottom.
Best to find a set produced by a VPP, which shouldn't be too hard for a popular class.
What's a VPP ?Problem with making your own polars is that you are limited to your ability and your equipment. So you can be sailing along at 100% but not realising you're not fulfilling the hulls true potential by not trimming the jib perfectly or by having a knackered main or a slightly grubby bottom.
Yes, but the extra tankage in the stern is offset by a reduced engine weight so I think it balances out.Boo has carried out extensive an extensive re-fit & mods, extra tankage in the stern, so Polars will be way out
A VPP is a velocity prediction programme that takes all of a vessels particulars and using white man magic produces a set of polars for a range of wind speeds and angles.What's a VPP ?
Thanks to all for their replies.
Boo2
What's a VPP ?
Boo2
