Gubbo
I am trying to connect-up a calorifier to a BMC 1.5 in a narrow-boat with skin cooling. The problem is, I really cannot see an obvious place to make the connections with the engine. There is a blanked-off outlet on the exhaust manifold/heat exchanger, but no other "return" connection. If I were to put the calorifier in-line with the engine cooling outlet pipe, then I am concerned that the reduction in bore will cause overheating. If I were to T off this pipe then perhaps no worthwhile flow will find it's way to the calorifier. I'm sorry if this seems really basic, but I really would appreciate some advice from someone who has a working installation to pont me in the right direction. (An e-mailable sketch would be magic)
Cheers
Rich G.
For details of my boat see www.sailpast.co.uk
Cheers
Rich G.
