Martin CY
Hi All
I am working on the keel bolts of my Hunter Horizon 23 (twin keel). There are 5 nuts on each keel. Most of them are in very good condition with almost no rust, but the silicon arround the nuts has peeled off and some of them are not tight enough.
So I have decided to remove one nut at a time, remove any old silicon and put them back together.
1) What tipe of sealant shall I use ? ( Sykaflex 291i ? )
2) Shall I put sealant between the 2 washers or only on the lower one?
3) Is it ok to use thread-lock glue when installing the nut or shall I Just apply sealant on the threads.
4) one of the nuts is very rusty (caused by rain water) andstuck, but not leaking. Any advice how I can remove it? I have tried wd40. Or shall I just leave it there as it is for the time being?
5) Is it a good Idea to cover the bolts with sealant or better to leave them open in order to re-torque when needed .
Any advice will be highly appreciated !))
