Please identify these fuses
Wandering Star
8 Feb 2009
Dorset
Here is a picture of my switch panel on my Dufour 2800. As you can see its A 9 switch panel with only 5 in use. I’d like to buy 4 more switches/fuses to mount in the vacant holes, what should I be looking for and where can I source them please?
noelex
2 Jul 2005
Do a search for "push button circuit breakers".
You should come up with some suitable models, such as those below.. You will need to check the dimensions and see if they are the same physical size.
PaulRainbow
16 May 2016
Suffolk
VicS
13 Jul 2002
There are two version of the 5700 series Vic. One is just a thermal breaker with the other option you can press the button and it breaks the circuit. Looks like the Furneaux Riddall one is just a breaker, which is much cheaper.
That's what I was wondering about.
I think the "2" prefix may identify the "Push to release/push to reset" type.
PaulRainbow
16 May 2016
Suffolk
Both types are available with the "2" prefix, see here: https://www.e-t-a.co.uk/fileadmin/u...tomaten/Thermisch/2_en/D_2-5000_2-5700_en.pdf
But, looking at the FR one, the part number ends with "DD", so that is push to release. RS give different prices for different current ratings, FR seem to be all the same, except the 30a one. So the FR prices are, in some cases, much cheaper then RS.
VicS
13 Jul 2002
F.R. do seem to be pretty competitive . Often better than 12volt planet. They are the goto supplier in the Solent area
RS always seem to be expensive which is why the school switched wherever possible to buying from Rapid Electronics.
Many years ago there was a shop in Gravesend that just ordered from various catalogues ( including the RS trade catalogue) for customers at trade prices. They were handy but not likely to still be there.
andsarkit
27 Aug 2015
Dartmouth
It seems to be a French standard trip. RS used to sell these from Stopcircuit but they no longer stock them.
Stopcircuit
I have some recovered from equipment scrapped a couple of decades ago.
Wandering Star if you have trouble sourcing them or are put off by the price drop me a PM and I might be able to help.
I'm a bit OCD about having switches matching even if the function is OK.
Wandering Star
8 Feb 2009
Dorset
Thanks for the help folks, the present fuses are indeed the ones identified by andsarkit. I’m sure the other suggestions would work but I wanted to use the exact same ones as the switch panel is set in a factory moulding so using other types/designs would stand out like a sore thumb. I wrote (emailed) Diruptor to Find out if they have a UK distributor or whether they would supply me directly but they haven’t responded.
I’ll be PM’ing andsarkit in the next hour to see if he can help out as suggested!
