PaulR
Slight play in the steering (can move wheel rim a few mm each way without moving the steering arm/rudder)
Whitlock instructions explain how to remove the gaskets between the wheel mounting boss and the main steering pedestal to take out the play but only one left - not sure whether solution if removing that one does not eliminate the play is then to have the conical shaped gear that goes into the steering collumn remachined (is this possible?) or replace it or live with the slight play- anyone had experience of this and got a good solution?
