robertt
No doubt a silly question, but if you have a boat with a planing hull, can you simply cut back the revs so that the boat doesn't rise onto the plane and use the boat in "displacement mode" in order to reduce fuel consumption and increase range, albeit at much lower speeds?
I imagine the stability of a deep vee hull might be less compared to a displacement hull and the wind might blow you off more easily but otherwise is this a feasible option?
