Piezo Electric Gas Lighter
footsoldier
4 Aug 2006
Welsh Marches
Hi, all.
Recommendations sought. The piezo ignition for my LPG oven has packed up - the pilot flame has burned the end off the the igniter. Once my gas engineer mate is eventually out of quarantine, he can hopefully find a replacement part, but in the meantime its a right bugger to light it with a match.
Bought a piezo "wand" from Amazon, but it's useless - very feeble spark that won't light LPG. Rather than suffer further trial and error attempts, can someone give me some experience-based recommendations for an effective brand with a good spark that is up to the job?
TIA
I have one of these, Force 4 gas lighter Very strong spark, I can also use it for lighting candles or setting fire to paper (if I wanted too).
Rechargeable. I find gas lighters work up to the first refill then are useless after that
Damn beaten to the post:):):)
One of these?
Bar-Be-Quick Gas Lighter | Wilko
OK, not my first choice of colour, but for 60p, who's arguing? At least you'll find when it tries to hide in the bottom of the drawer
Thank you very much for the suggestions. Looks as though the Wilko one is unavailable, but I quite fancy the Force 4 rechargeable (didn't know such a thing exists!) Much obliged to all.
Not my experience. If you use the correct adapter you can get the gas in. It took me a while to perfect this, which is the reason I now have two on the boat and three at home.?
I never found the spark type lighters very reliable, much better, in my experience, are the type containing gas so the piezo spark ignites a gas flame and you use the flame to light your gas cooker/hob. Easy to refill the gas in the lighter although, as others have said, you have to select the correct adapter for the make of lighter. However, some lighters refill direct without an adapter just using the default nozzle.
Www.solocoastalsailing.co.uk
Hi, all.
TIA
Over the years I've had or currently have several types.
The gas filled, piezo ignited, type work best especially for lighting ovens and grills but they do need refilling with lpg from time to time from a gas cigarette lighter refilling cannister.
A battery powered , non piezo, lighter gives a continuous stream of sparks and works well. I think I will stick to one using a replaceable AA battery rather than mucking about with a USB charger..
Types which emit a stream of sparks as the button is pressed and released wok well
The least satisfactory are the types which emit just one spark as the button is pressed. They are particularly difficult for ovens and especially grills
The problem with spark lighters on propane is that the gas is heavy and sinks out of the burner, you need to get the spark as low down as possible.
The lighters that have their own gas to light a flame are much better.
I never found the piezo lighters lasted very long on a boat. I have an IMCO flint one that is brilliant.
It is decades old but I don't think they are made anymore and they go for silly money on ebay.
Quite a bit cheaper here plus on sale at the moment:
Rechargeable Electronic Stove Lighter
I've now found what appears to be the identical item on fleabay for £7.89 post-free! In view of the endorsements here and at that price, I think I'll give it a try. If it's unsatisfactory, then the gas-filled type will follow.
Thanks everyone for your speedy and informative responses.
