Vid
There's a lot of advice around on picking up a swinging mooring single-handed but I've not seen anything about trot moorings.
My 24ft Achilles is moored on inner trots on the side of a large-ish river, with some strong currents running at different states of the tide. It is moored with a pair of lines fore and aft and there's a bridle line between the buoys.
When I leave the mooring I bring the fore and aft lines together and attach my own float to them before ferry-gliding off if I can. When I return I always moor into the tide.
If I have crew with me, I send one to the foredeck with the boathook to pick up one of the lines (doesn't matter which) and attach that to the cleat there. From the cockpit I then pick up one of the aft lines and get that on board. We then set the lines properly once attached.
I've not yet tried this single-handedly. There's quite a lot to do as it is, what with helming and adjusting the revs/gears on the outboard engine in the cockpit well and picking up the aft lines. It's also an inner trot so I'm aware of other boats around me.
If I just pick up the aft lines from the cockpit then I'm concerned the bow will be pushed out by the tide and turn us around by the time I've reached the foredeck and am picking up the forelines.
I thought about attaching a temporary line to one of the trot buoys but there's nothing on them above the water to attach to. I don't think I can run a line from the foredeck aft as although I might be able to hook the lines in the water up and loop this around there's nothing for them to hang onto so we'd be pushed back onto the boat on the trot behind by the time I've attended to the engine and gone to the foredeck to pull us forward.
How would you suggest I can attach the forelines whilst remaining in the cockpit to helm and deal with the outboard? Fortunately it is a relatively light boat but the tidal flow can be upto 4kts at times.
