tonydyer
The Perkins Perama engine of my Moody 35 (1992) has just started dumping quite significant quantities of oil into the bilge (about half litre per hour running – nothing when stopped). The accessibility of the sump gasket is dreadful - because of longitudinal hull strength members either side of the engine, I believe that it would be impossible to drop the sump without raising the engine first. I have however managed to get my fingers around 95% of the sump gasket and can find no obvious evidence of leakage. There is definitely nothing coming from the fwd shaft seal, but the aft seal just cannot be observed.
Has anyone experienced this problem? (I note L. Watkins’s message of 10th June and 14th August, but it appears that it refers to a different engine). Is there anywhere else that the oil could be dumping from? I tend to discount the sump corrosion problem as there appears to be no loss of oil when the engine is stopped. Has it got to be the aft shaft seal, and is there a way of checking this without raising the engine?
Tony Dyer (tonydyer@lineone.co.uk)
