MarkJohnson
I am looking at a boat which was epoxied about 13 years ago. My surveyor has found she now suffers from osmosis.
I have found out that the previous epoxy treatment was in the form of what is called pepper potting. As far as I understand, that means the process requires that holes are drilled into the hull to dry it out. I assume epoxy is then used to fill the holes and to then cover the hull.
Has anyone any experience of this system, and what is the long term effect on the hull?
May be I should walk away from the boat, but she is a terrific sail and looks so good (Gibsea 90)
TIA
MArk Johnson
TIA
MArk Johnson
