Ammonite
According to the latest edition of PBO these are not suitable for use on boats. I think they might need to invest in some new experts / proof readers!
Can I ask who wrote the article? I know that one regular contributor is totally confused as to the difference between DZR and 60/40 brass, despite my emailing him with the reality.According to the latest edition of PBO these are not suitable for use on boats. I think they might need to invest in some new experts / proof readers!
The comment is attributed to James Turner of Meridian Zero but its hard to tell if this is his view or he has been wrongly quoted. It starts off talking about brass as being unsuitable but then links this to DZR in the same contextCan I ask who wrote the article? I know that one regular contributor is totally confused as to the difference between DZR and 60/40 brass, despite my emailing him with the reality.
I get that as there's a good chance they aren't made of the DZR but what the article actually says is "Skin fittings should last 30 years, not five. What's more, if you put a boat in a marina with DZR fittings, where there's a lot of stray currents from other boats, you can end up with one that lasts three years and crumbles in your hands" which in my mind suggests they believe that DZR valves sold by the likes of ASAP aren't up to the job.I can well imagine that the ones from China at 50p a pop might be labelled DZR, because they'll sell better, and still crumble, but not decent ones made of real DZR
Unfortunately this is technobabble. 'Stray currents' are blamed for all sorts of problems but the reality ìs that it is almost always a more basic fault. If DZR seacocks are not electrically connected in a bonding loop they will last for many years.I get that as there's a good chance they aren't made of the DZR but what the article actually says is "Skin fittings should last 30 years, not five. What's more, if you put a boat in a marina with DZR fittings, where there's a lot of stray currents from other boats, you can end up with one that lasts three years and crumbles in your hands" which in my mind suggests they believe that DZR valves sold but the likes of ASAP aren't up to the job.
I have a DZR ball vlave from ASAP that is still good after 14 years. Another, from the same batch, I replaced when it was 9 years old even though it was working fine, I then sawed it in half and subjected it to some very heavy hammer blows. It showed absolutely no signs of weakness. I would certainly not trust the author of that article unless he quotes his source/evidence.They are likely to crumble to mush within 3 years according to the article! ;-)
No one is advocating brass. The latest PBO article on seacocks is suggesting that DZR (CW602N) may not be suitable and has a service life of 5 years (their words not mine)I have changed 100's of seacocks & fittings over the years.
I refuse to fit anything that may have been made in China.
Unless bronze is specified, I fit CR marked CW602N DZR from a reputable supplier, where I can trace the source, with a certificate if needed.
All the ones I fit have stainless handles.
Anything brass has no place on a boat.
I prefer to keep the water outside & sleep at night.
Slightly topped you there, mine are 37 years old. Equally DZR and equally still working fine. There is a very slight coppery appearance on the cones but absolutely no concern about their integrity.I hope my 34 year old DZR Blakes don't get to hear about this. There could be trouble.
I took issue with BSD when his article was first published. He was not able to show me a dezincified DZR valve. Since then skin fittings and hose tails in DZR have become available.Ben Sutcliffe-Davies is the surveyor referenced in the article and although I originally thought they had inadvertently used brass and DZR interchangeably I suspect this isn't the case and that despite what others say he doesn't think DZR is suitable judging by this article...
Seacock misconceptions busted - Yachting Monthly
He is also not alone judging by a number of articles I've just Googled suggesting that DZR only has a lifespan of 5 years so has the advice changed again since the brass debacle in which case why are DZR valves still being sold as suitable for marine use?
When the problem with brass valves being fitted came to light Yachting Monthly were publishing (in June 2011...)
"This is now known
as DZR (dezincification-resistant)
brass and has the EN designation
of CW602N. This material is
proven to be the equal of bronze
in a saltwater environment
and is now in common use.
Unfortunately, the other similarity
it has with bronze is price."
....and there's plenty of sources that say the same thing today so what's the truth?
I am living on borrowed time.They are likely to crumble to mush within 3 years according to the article! ;-)
I replaced some of mine this year so I think I will only partially sink?I am living on borrowed time.
Some of mine are 55 years old!
