Painting Aluminium
VO5
14 Sep 2009
Gibraltar, RGYC.
I have done some preliminary research and have encountered really complicated explanations with regard to preparatory chemical treatment.
As the item in question will be for cabin use and will not be exposed to the elements, I wonder if any member here has successfully used a spray paint that will not flake. Thanks.
Bilgediver
6 Jun 2001
Scotland
Once you have applied a good base of etching primer what goes on top is probably of little consequence. The etching primer is important as otherwise the paint may possibly bubble off.
Some of the grey aerosols of primer in Halfords are an etching type!
DownWest
25 Dec 2007
S.W. France
We used to use etch wash primers on ally.Very thin, as weight was a consideration on aircraft. Usually sprayed.
I found the local B&Q has paint that has a self etching component. One coat as a primer/undercoat. Two coats as a finish. Just used it on our ally run-about. I will tell you next year how good it is...
Stemar
12 Sep 2001
When I refurbished a couple of window frames on Jissel, they really should have gone in the bin, but the replacement cost gave me palpitations, so I ground out the corrosion and filled with platic metal. To finish, they got a couple of coats of Hammerite non-ferrous primer followed by silver Smoothrite.
Still looking good about 3 years on.
theoldsalt
24 Nov 2010
Bristol
I used "Hammerite Special Metals Primer" and then "Hammerite Smooth" brush paint on my wind generator. Very satisfactory so should be Ok for inside.
maby
12 Jun 2009
Go to your nearest Land Rover dealer - they are all aluminium, so they will have everything you need to do your painting...
VO5
14 Sep 2009
Gibraltar, RGYC.
I have today bought two products, both sprays.
Both manufactured by HYCOTE.
Hycote HyGuard ZINC PRIMING and Acrylic Formulation Gloss White.
I will let you all know how I get on.
