Becky
An implant is a titanium root-shaped peg that is placed in the bone of either jaw, and left to heal. Titanium has a strong affinity for bone, which means that the bone will grow onto the implant surface such that it becomes integrated into the bone itself. The bond is incredibly strong, and the implant cannot be removed. Well, it can if it is in the wrong place or something, but only with special equipment. The healing process is between 3 and 6 months, depending on bone quality.Some implants can be placed and immediately loaded.
But, the important thing is that they work, and once placed, the tops are just screwed into a threaded hole with a hexagonal top 3 mm or so. So, once placed, they cannot hurt you when being prepared for the replacement teeth or bridgework, or even denture support. The cost depends on what you intend to finish them with. A fully edentulous mouth (no teeth at all) with say 8 implants lower, and 10 upper, with full tooth replacement would cost up to the same as a small Bav/Jen/Ben. But very roughly a one-tooth gap would cost about the same as a bridge for the same space.
