I seem to remember that was in part caused by the ship starting to turn, then stopping the turn, then turning again
But would you go below while passing at that range? At that passing range, I'd be thinking I'd have to watch for potential wake from the large boat.
The MAIB report doesn't address rule 8 at all - I think it's pertinent:
(my bold)
Even if your action is to "stand on", the rules still require this.
To be honest I can see myself doing much the same thing in my own home waters - I am so used to sailing there that I "know" what the ships are doing and so automatically discount them
I would suggest that in the mind of the skipper the risk of collision never existed - otherwise he would not have gone below when he did.
You may do it, but this accident indicates strongly why you shouldn't. You simply can't make assumptions about the behaviour of other boats in range - you have to assume the worse. It is never safe to leave the boat on autopilot without a lookout for a longer period of time than you are sure the boat is safe given the proximity of other craft. The approaches to Felixstowe are busy and the situation can change pretty quickly - as this event demonstrates.
I have to wonder if when the skipper went below he really expected to be as long as he was.
But the skipper assumed the dredger would stay within the buoyed channel - I do the same when sailing in the Solent, if I see a ship I assume it will stay in the buoyed channel and would have no concern getting within 100yds provided I was outside the channel.
That was suggested, but I don't think it did. .
IIRC the tanker started its turn to starboard pretty much as usual but a motor boat was in the way with some sort of engine or propulsion problem, so the tanker turned slightly to port, then dead ahead, then turned again to starboard. All clearly shown on its track as published. Not sure that sound signals were used correctly either. The net effect of course was that their course was further West than usual, and the yacht was unable to squeak in front of its bows.
I can't
It's a while ago, though, and my memory could be faulty.
http://http://www.ukmpa.org/downloads/xcH_jksi_Cfsg_s23/court_judgment_mca_v_roland_wilson.pdfI can't find the report on the MAIB website, so perhaps they have pulled it, but I don't see any port-starboard-port wiggle here
In his summing up the judge stated "In order to avoid crushing the power boat the tanker arrested his turn to starboard by applying port helm of 10 degrees." Presumably this had been stated earlier in evidence to the court. The you-tube clip you show is I think the reconstruction put together by some experts to illustrate the prosecution case. It did not include any info on the broken down powerboat that caused the change in turn of the tanker.
My memory wins!! (A rare victory.)
Anyway, enough thread drift for now.
